More MTM spring details..
After a lot of heat gunning over at Jee's house I still had no luck controlling the rubbing on my car (I did run a throttle adaptation and recode my key fob thanks to Jee's cool software). Talked a lot to my tuner this morning and I think I am going for a set of coilovers so I can dial in exactly the ride characteristics that I want. During the spring only install (w/18x8.5 RXII w/ SP9000 225/40) these were the amount of drop he recorded, front 30mm, rear 6mm, and using a protractor he said the car was almost completely level. He added a degree of negative camber but I still rub. The ride with the springs is great, but I keep rubbing my liners and on screw that attaches to the fender lip (this is the part that makes me nervous). Good news is that these liners cost under $30. I just have to take it easy until the KWs come, and hopefully my VM2 will be here by then as well.
Kevin, perhaps the offset on your wheels is not right. I have MTMs too, (m)
with 17" MM Spiders-no rubbing.I would think that you would be able to go to a larger-diameter wheel as you did,if the caliper clearance is there,AND the offset is correct.I'm curious because I want to go to 18s myself.So, what's going on?
PSUEng
03-16-2007 06:19 PM
PSUEng
13
03-10-2007 10:13 PM
rbella4
Wheels & Tires Discussion
06-13-2002 12:31 AM
Jim Lamb
04-09-2001 06:23 PM
S4MULA
02-05-2001 08:55 AM
