My FATS times for TIP with GIAC (race mode). Also format probs, cpu nerds wanted)
<center><img src="http://i27.tinypic.com/28sx1n4.jpg"></center><p>Ok so I took some FATS times last night on my 2000 Tip that is stock except for GIAC ECU running race mode with a 1/4 tank of 100 octane. I used Noah's FATS calculator and it said 5.7, which is not bad for almost stock. I'm also fairly sure that I didn't do it super accurate. Problem: It seems that each new log I make opens up in the same original log document. It just keeps adding. If I change the name of the log, it will create a log of that name but the data isn't formated correctly and its not the same type of file. But it also records the data of the rename ed log CORRECTLY in the original log, which is just getting longer and longer. In the pic all my data keeps being added to LOG-01-003-xxx (original) and LOG-01-003-xxx RACE 1 100 is the one I renamed that is improperly formatted, but its data was also added to the end of the first file (in correct format). Can someone help sort this out?
alanaudi
12-07-2001 08:39 PM
George @ BostonAudi
09-27-2000 04:28 PM
