My First Vag Log and Graph...rpm/req boost/actual boost...any suggestions?
no problems, is there other data I should include...
this was the first time ive done this so I was pretty impressed with myself. It looked as though though the car was running good to me. actual boost and requested were right on.
You're fine, the boost will always fall sharply between shifts. As far as....
anything else goes, since you're polling the engine computer at a very slow rate, try to measure only one group at a time. I always like to look at intake air temps and exhaust gas temps. Usually 034 and 043 work out well for EGT's...I think those are the numbers, it's been a while.
Good luck with everything. It's always good to see a baseline run for your car and save it for future reference when you think something IS going wrong.
It's just too bad we can only take a couple samples a second, but I guess it's better than nothing.
Mike
Mike
Quattromatt
02-11-2005 04:47 PM
Neon01
10-31-2002 09:21 AM
shaneS4
10-28-2002 03:39 AM
Fluffhead
07-31-2002 10:26 AM
Dangler {/KAWF} BUMP
11-05-2001 02:40 PM
