NEED HELP! sweaking window / door frame is driving me nuts.
I've tried everything from dishwashing liquid, silicon spray and a petroleum based spray designed to stop rubber squeaks.
It's coming from the upper part of the door but I don't know if it's the window or the door frame, nor if it's the top or the A pillar.
I've been working on this for months!
I've tried probably half a dozen types of lubricants (silicone spray, 303 rubber/vinyl dressing, motor oil, high temp brake caliper grease, other lubes, etc.) and some of them work for a day or two, but they inevitably dry out the rubber weatherstripping and the squeaks return.
I tried removing the black B-pillar covering on the exterior side and the squeaking/rubbing sound goes away, so I know it's involved. In my case, the sound is coming from the 1 inch rubber material lining the door opening (on the body of the car, to which the door makes contact with) rubbing agaist the black metal B-pillar covering. When I lube it liberally, the sound is almost eliminated, but the lube eventually dries out and the sound returns.
I think I eventually need to buy BMW gummiflege, Door Ease, or Krytox (Audi product) to lube it properly.
One thing that I'll also try using 1/4 inch vinyl tubing (link below) on the door to create a tighter seal, in hopes that there's less rubbing.
As a consulation, I know I'm making some progress. Now I just need to stop my glove box from rattling!
Damn 7 year old car!<ul><li><a href="https://forums.audiworld.com/a4/msgs/2324427.phtml">https://forums.audiworld.com/a4/msgs/2324427.phtml</a</li></ul>
mcashman1975
04-09-2013 08:56 AM
Wrinkledpants
08-17-2008 04:54 PM
audi-bahston
05-30-2006 10:43 AM
bryonblue
04-11-2001 12:27 PM
