Odd sound and hesitation... no blue smoke (hopefully ever)...
ok any of you S4 guys ever experience this.. i think it is a IC hose that is loose.
description:
under full load in 2nd or 3rd gear (doesn't happen in 1st) just above 4k rpm a different sound happens. the normal rush and turbo sound happens and then it turns more into a wwwwhhhhuuuuuuuwww (not a tee kettle noise), but more of a different air flow noise. i took it into audi and they said my hoses looked good and that they could not recreate the effect (i took out the chip when i went in). Also, i am getting abrupt throttle/boost loss when i let off the gas during this boost range.
- this noise only happens when i am chipped
- at peak boost at around 4k+ rpm
- in mid gears
* i haven't gotten a check engine light from this
Thanks in advance for any insite!!! :>
description:
- in mid gears
I am having the EXACT same problem...
Mine started when I swapped the GIAC ECU for the stock ECU for two days.
Thinking of clearing the ECU tonite with "000".
TBB and BPVs wer fine here too.
