Oil Leak - Passenger Side Turbo. I just had valve covers, cam tensioner seal, and cam caps replaced
Old Jan 7, 2008 | 08:21 AM
batsoff's Avatar
Default Oil Leak - Passenger Side Turbo. I just had valve covers, cam tensioner seal, and cam caps replaced
but I still have quite a bit of oil on my passenger side turbo and the belly pan.
What's the best way to get a look at this turbo?
Take the driver side wheel well out?
front bumper off?
When I look down the drivers side of the engine from the top I can see little plumes of smoke coming up from near the wastegate of the turbo is, but I have no idea what is leaking.
How can I get a closer look?
Here is a pic from the bottom (after I cleaned it up):
<img src="http://pictureposter.audiworld.com/47680/oil_leak_turbo_from_below.jpg">
From the top:
<img src="http://pictureposter.audiworld.com/47680/oil_leak_turbo_from_above.1.jpg">
Before I cleaned it up it looked like this:
<img src="http://pictureposter.audiworld.com/47680/sample_oil_leak.jpg">
Old Jan 7, 2008 | 08:36 AM
Nigel (no more S4)'s Avatar
you sure that's not just the valve cover leaking onto the exhaust manifold there?
Old Jan 7, 2008 | 08:44 AM
batsoff's Avatar
Default Not sure... just noticed it yesterday and tried to take some quick picks. Need to get a better view
of what is going on.
What's the best way to get a good view of that area?
Old Jan 7, 2008 | 08:51 AM
Ah10@WMS's Avatar
thats my guess too! btw ygm
Old Jan 7, 2008 | 09:06 AM
Default best view
pull the headlight, start the engine and let it idle. Get a decent flashlight and look around the bottom of the valve cover (look in from the headlight housing area)
Old Jan 7, 2008 | 09:11 AM
roll-n's Avatar
Default Same thing happened to me the other week.....
Had the same work done and the car was still leaking quite a bit of oil. It was all over the turbo and the same places you described. Turned out to be a bad rear cam seal that was defective when they put it in.
Old Jan 7, 2008 | 10:19 AM
batsoff's Avatar
roger that... thanks NigelS4.
IPStevieB
Audi allroad
Dec 8, 2015 10:46 AM
isleblue65
Jul 4, 2011 06:45 PM
iNfiNkC
Jun 27, 2008 07:48 AM
astone (Andy)
12
Mar 28, 2007 04:06 PM
Ben's e//S2
11
Aug 1, 2005 04:53 AM
