Ok...I'm pissed....reclamation water used in sprinklers at work..damaged car finish
AudiWorld Expert
I got these watermarks from reclaimed water used to water plants at work...I have them all over 1/2 my hood...and my left front fender. They WILL NOT come out...I have clay barred.....used Meguiars cleaner...reglazed and rewaxed....they are still there. I washed the car within 7 hours the water drying on my hood.
Any suggestions? I am about to go to my auto body shop buddy and ask him to use rubbing compound on it. This, to me, is really bad.<p><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/steveshsig1.gif" border="0">
Vinegar and water bath will remove hard water spots. Try it.
I had a similar problem and it fixed it like magic!<p><img src=" http://pictureposter.audiworld.com/AudiWorldPics/2000/Faster.jpg">
<a href=http://registry.audiworld.com/audi/registry/details.asp?car=5245>My Ride.</a>
How are you going to stick an S4 in a water bath?
I agree, use some vinegar and water or some other mild acidic solution. Chuck your claybar and rubbing compound. Your S4 is too new!
Acid (hydrochloric?) is what's sold at stores for cleaning hard water stains in bathrooms.<p>Andrew Lee
Photos: http://briefcase.yahoo.com/hwaandrewlee
<a href="http://registry.audiworld.com/audi/registry/details.asp?car=1061">Registry
My wife is jealous of the car as it is....just think if she found me taking a bath with it!
<p>Christian J. Long
President - Quattro Club of Florida
Orlando, FL
'00 A4 1.8tqsm
'97 A4 1.8tqm
'87 944S
'90 Audi 90cs
Past Audis:
84 CGT, 85 CGT, 87.5 CGT
90 CQ, 98.5
Orlando, FL
'00 A4 1.8tqsm
'97 A4 1.8tqm
'87 944S
'90 Audi 90cs
Past Audis:
90 CQ, 98.5
a brief lesson in acids...
vinegar is not hydrochloric acid. Hydrocloric acid is what is found in
your stomach to aid in the digestion of food. If you were to put
hyrdrochloric acid on french fries, well.. they would probably dissolve,
and you'd burn the inside of your mouth and esophagus.
vinegar is acetic acid. friendly, often overlooked and versatile chemical
tee-hee-hee
Earnie<ul><li><a href="http://www.specialtyfoodsnet.com/shop/vinegarrecipes.htm">http://www.specialtyfoodsnet.com/shop/vinegarrecipes.htm</a</li></ul>
Once you get them off, put a GOOD finish on it, I recommend Zanio, but others will also work.
And keep the finish current. That's the best protection you can do for water spots, insects, road grime, bird droppings, etc. That, and speed. My family has standing orders to remove things like bird dropping from any of our cars using whatever it takes, artical of clothing, drink, or even pee on it if that's all you have to get it off! ;-)
Clothes, etc., are cheap compared to fixing a damaged finish.<p>Jim De Arras
<a href="http://www.imola.org">2000 00 Imola/Onyx/Alcantera S4</a>
MTM Stage II (Stage III on order)
MTM Full Suspension
MTM/Pagid Brake pads
UUC Short Shifter (original 20%)
Michelin Pilot Sports.
SmartTire Tire Monitor
MTM Full Suspension
But no matter what you do the lube will wash away and friction will increase causing damage.
<p>matthew(most moderated)k
00 Porsche Boxster S
(Previous S4 Owner)
Grand PooBah of the HIG World Wide Consortium
(Previous S4 Owner)
