Okay, so me check engine light went on and my local dealer said my oxygen sensors went south...
I have aftermarket Dp's installed and the sensors seemed to have gone bad after the DP intallation. The question is to those with aftermarket dp's (stage II+), if you replace your sensors, does this fix the problem or does it come back eventually causing you to repeat the process all over again? I'm more than willing to replace the oxygen senors but according to the mechanic, it they will eventually go bad as well....have you guys experienced this?
srosie
12-06-2000 01:17 PM
