OT: My gf's audi 100 is overflowing coolant when it gets hot; air in the system? Should I flush it?
When you say "gets hot" do you mean over-heat? Where is the temp needle when it happens?
If it's over-heating, make sure the radiator fan is kicking on. The older Audis are infamous for having them crap out...thus causing overheating...and the coolant geyser you see. (I know it ohhh too well!). Thermostat can also be an issue with that symptom.
Guess I'm just asking for more info...
--morgan
--morgan
Any leak in the system prevents it from pressurizing.
If it can't pressurize, that means a lower boiling point. Lower boiling point means the system will boil over, and fluid will come out of the overflow reservoir (and wherever the leak is).
Ok, so no overheat. Is it overflowing from the expansion tank? Or are you just noticing it...
on the floor of your garage (could be h2o pump dying, crazy leak in radiator and/or hoses)?
If it's out of the expansion tank and you're not over heating...then RKA is probably dead on.
--morgan
--morgan
quiksilverly
59
07-04-2019 01:30 PM
sidespar
21
01-05-2008 07:45 AM
