Pics From My Greddy Profec B (Spec I) Install As Requested By CasaBlancaS401
Junior Member
Note: This install is NOT that difficult. A less than experienced back yard mechanic can do this. The first attempt is very time consuming, because quite frankly, YOU are AFRAID to F*ck up YOUR S4! (took me 4 hrs). An expereinced back yard mechanic can do it in 1.5 hrs, or less (in my opinion).
There is one thing NOT shown here (no pics) - the electrical (power) connection to post 75x (STFA) and where I installed the ground wire (on the chasis - near the fuse box).
Also, you should look at the diagrams (on AudiWorld) that illustrate the connections for running a MBC and N75 in parallel. It will show you how the turbo and wastegate are plumbed into the N75 - u have to use the SAME connections on the Profec B - but YOU WILL NOT be running the Profec B in parallel with the N75.
Here Are The Pics (I hope that the text is helpful):
Profec B Stepper Motor (Turbo - Wastegate Interface) in coolest area of engine compartment
<img src="http://pictureposter.audiworld.com/56250/profec_b_stepper_motor_-_passenger_side_-_in_front_of_pollen_filter.jpg">
<img src="http://pictureposter.audiworld.com/56250/profec_b_stepper_motor_-_side_view_-_passenger.jpg">
Hole Drilled Into ECU Box For Stepper Motor Control and Vacum Lines to Profec B (inside car)
<img src="http://pictureposter.audiworld.com/56250/hole_drilled_into_ecu_for_vacum_line__stepper_moto r_control_cord.jpg">
Hoses From Stepper Motor To Wastegate and Turbo thru Grommet in Firewall on Passenger Side
<img src="http://pictureposter.audiworld.com/56250/firewall_grommet-passenger_side_-_wastegate__turbo_hoses.jpg">
Vacum Line (T) Connection To Fuel Pressure Regulator Vacum From Profec B via Grommet in Firewall (Driver Side)
<img src="http://pictureposter.audiworld.com/56250/profec_b_vacum_line_connection_-_top_view_-_driver_side.jpg">
<img src="http://pictureposter.audiworld.com/56250/t_connector_intersects_fuel_pressure_regulator_vac um_and_feeds_profec_b.jpg">
N75 is STILL Intact Electronically (so the ECU doesn't throw CELs)But the Wastegate and Turbo Connections Have Been Severed. N75 No Longer Controls Boost On My Car. Note the RED CAP on the N75 where the Wastegate hose was disconnected. There is a BLACK CAP where the Turbo hose was connected.
<img src="http://pictureposter.audiworld.com/56250/profec_b_turbo__wastegate_hoses_behind_n75_that_is _still_intact_electronically_-_not_functional.jpg">
Profec B (Spec I) Mounted Inside The Passenger Compartment To Allow Driver Access To Boost and Wastegate Control (via manual control *****)
<img src="http://pictureposter.audiworld.com/56250/profec_b_spec_i_mounted_under_dash_behind_steering _wheel.jpg">
I Endorse The Fact That This Post Was NOT Submitted By One of The PEB Boyz.
Junior Member
In Between Posting Fights With Some of the 'PEB Boyz' & 'S4nit Loves A$$' - I Try To Make Some
meaningful contributions to this board from time - 2 - time.
Thanks for your reply.
I remember it was said that the MBC was *the* only way to go
And EBC's were a no good piece of ricer ****. Now I've seen a couple of good EBC applications and it seems to be working well.
Kudo's for bucking conventional PEB wisdom and going out on a limb.
Or maybe it was just the Kamei Eyelids ;-)
jaytopia
10-03-2006 04:07 PM
S6 4RiNGS
Audi Original "S" Cars
04-09-2006 07:37 PM
808Guy
22
07-18-2005 11:52 AM
brrman
09-15-2004 07:28 PM
VW Weezer
01-21-2002 08:06 AM
