Plug anti-fouler O2 sensor mod seems to be working so far.
Old 01-24-2006, 07:11 AM
Senior Member
Nick Gustas's Avatar
Default Plug anti-fouler O2 sensor mod seems to be working so far.
Last friday my bank 2 ignition amp decided to turn off for a bit, while under full boost in 6th.
The excess fuel from non firing cylinders 4,5,6 melted my bank 2 cat, and blew quite a bit of it out the back. Caused quite the spray of orange chunks in the rearview, and a flashing CE light. I immediately thought I had blown my engine with the power loss and orange spray out the back..
Soo, after "fixing" the amp by cleaning the contacts, car ran fine, but I had a DTC for bank 2 warmup cat efficiency. Since the exhaust didn't smell, I figured some of the cat must be left..
I pulled the cat for inspection, and found this:
Frothy!
<img src="http://tychl.txf.com/catmelt/melt1.jpg">
<img src="http://tychl.txf.com/catmelt/melt2.jpg">
I knocked off most of the chunks, and opened the channels as best I could. I did a little more work after these pics. Looks good when held up to a light.
<img src="http://tychl.txf.com/catmelt/littlebetter1.jpg">
<img src="http://tychl.txf.com/catmelt/littlebetter2.jpg">
I'll deal with the cat in the spring.
For the "mod", I used the 42009 non fouler, and drilled it out using a lathe and a 19/32" drill. I tried a 5/8" as the archives said, and it was too big, fouler threads broke off.
Came out to this size:
<img src="http://tychl.txf.com/o2mod/drilled-out-diameter.jpg">
Diameter of sensor:
<img src="http://tychl.txf.com/o2mod/sensor-diameter.jpg">
Sensor in non fouler:
<img src="http://tychl.txf.com/o2mod/tight-fit.jpg">
Since the walls of the non fouler are so thin after drilling, I brazed the non-foulers together, figured it might help keep it from cracking off.
<img src="http://tychl.txf.com/o2mod/brazed.jpg">
This morning I went through the DB047 cat check that was failing after the "incident" and setting the B2 cat efficiency DTC.
Passed!:
<img src="http://tychl.txf.com/o2mod/catok.gif">
It even passes faster than my "good" cat on B1.
We shall see how this works out long term, so far so good.
Old 01-24-2006, 07:20 AM
lemieux@curbside's Avatar
so u used 2 per side (2x HELP 42009) ? oh and just gut that cat all the way
Old 01-24-2006, 07:24 AM
Senior Member
Default Yep, drill one out, leave the other alone, stack them, sensor goes in drilled one, non drilled in.
exhaust.
I was going to gut it, but it cleaned up so easily and seemed to be working at least a little, I figured I'd give it another chance
Old 01-24-2006, 07:26 AM
mbox's Avatar
glad it worked for ya. Enjoy!
Old 01-24-2006, 07:28 AM
Junior Member
Chaddy's Avatar
Sheesh. Didn't know the substrate would melt so readily!
Old 01-24-2006, 07:29 AM
Elder Member
PSmalls::DoggieStyle's Avatar
Heh, nice work Beavis.
Old 01-24-2006, 07:35 AM
Senior Member
I'm glad someone finally found something that works, and just in time for me
dscottjr's Avatar
are 19/32 bits readily available?
Old 01-24-2006, 07:38 AM
Senior Member
Default Me either! I think metal matrix cats might do a better job of spreading localized heat.
Though the ceramic makes it really easy to scrape off melted parts. Still surprising to see ceramic melt like that.
Old 01-24-2006, 07:40 AM
Senior Member
Default uhhhh, maybe at a hardware store? I know they are right next to the lathe :P
Might be better off ordering online, I saw a few on EBAY/Froogle.
Quick Reply: Plug anti-fouler O2 sensor mod seems to be working so far.
