Pop or Click from Clutch Pedal
Greetings,
After viewing the archives, I was wondering if anyone else had a similar problem, and what was the resolution. The click is most noticable when you release the pedal slowly (car not in gear/car is off). I know for a fact that its not the clutch kill switch.
The first suggestion is to check the return spring mounted under the steering column. Please let me know if you have the part number"s".
I will be checking out the spring tonight.
My first original impression was one of the fingers on the pressure plate was broken.
Please provide insite and recommendations.
Thanks,
James
2001 Audi S4 "Stock" 45K miles
Thanks,
James
Thanks for the Replys
Hello,
I'm going to check the spring tonight, and if its fine then I guess I'll be in the market for a clutch assy. Oh JOY!
I just wish this could have happened after I finished restoring the '67 Bug.
Once again, thank you. I'll post results tomorrow.
James
James
