Probably paranoid, but does it matter whether the t belt guard sits in relation to the serp idler?
In this picture, the serp idler (fan pulley) is behind the vibration damper t-belt guard. There seems to be a little space cut into the fan pulley where this guard sits on top of it. My question is if it's ok to install the fan pulley so that it is on top of the t-belt guard (i.e., the plastic guard would be behind the metal - basically opposite the way it is in the picture)? I did this because the guide said to install the t-belt guard first, then the fan pulley. What this did was push the plastic guard back some, and I couldn't get it out it front, so I just left it. My only concern is that the plastic guard will rub on the t-belt idler wheel that sits behind it. Even if it did rub, I'm not sure this would cause any damage - wouldn't it just eat away the plastic until it spun freely without rubbing?
Anyway, I'm not sure the way it is supposed to go. The car is still on a lift, but I've re-installed the lock carrier, so it has some work to do to get it back to where it was so I could put it on the other way (pulley then guard).
Should I re-do it or I am just paranoid?
<img src="http://pictureposter.audiworld.com/12726/100_0429.1.jpg">
I remember the same dilema when reassembling mine. Previous
photos saved the day.
My 2cents...
First you need to determine if it's actually rubbing. Can you get a wrench on the Crank Pulley nut with the Carrier in place? Turn and listen.
If it is rubbing I would say besides wear, another issue is will it interfere with the belt tracking? That one alone would probably lead me to fixing it.
Good luck
Tony
My 2cents...
Good luck
Tony
Plastic goes behind. If you leave the plastic tab in front of the idler bracket it will rub on the
crank pulley.
There is plenty of room between the plastic and T-belt when placed behind the bracket. Trust me I had the same question but figured it out.
The_Jerbel (Jordan)
9
01-31-2008 06:10 PM
thrash
09-14-2005 11:46 PM
b00staholic
08-05-2004 04:19 AM
VAP
06-23-2002 08:59 AM
