Pulling The Alternator
Not too bad. Put the lock carrier in the maintenance position, remove the belt, pull out a couple bolts, remove the passenger side IC hose for access, remove the ground and wire clip from the rear of the alternator, and wiggle it out. Putting in a new one is the tougher part since sometimes the bracket on the new alternator needs to be ground down a bit to fit. And don't forget to swap the pulley if needed.
Another one bites the dust - SCCA PDX Summit Point killed mine
Battery light came on in last session. Pulled in and idled to cool down. Battery voltage at idle was 15V and climbing. Disconnected the starter and alternator line from the battery terminal and zip-tied the ECU/ignition line to the battery post to limp home. Recommend driving in daylight as the HIDs will kill the battery as fast as the ignition drain.
mark955
12-05-2005 11:15 AM
vaughn-gotti
11-08-2005 09:03 AM
HoTTrod
12-28-2001 10:58 AM
