Putting the tranny in...I pinched it seems to be a coolant line......
Coolant everywhere....It isn't in the clutch which is good.
When I squeeze the there is a squishing sound coming from underneath the fuel rail. what is the hose part number and how hard it that to replace?
I can't tell either. It just started leaking......
But when I squeeze the radiatior hose i can hear a hole in the hose underneath the driverside fuel rail. I believe that is where the coolant pump is. How the **** did i pinch a coolan't line putting up the new tranny. It sucks. Should I put in the new tranny and worry about the coolant leak later?
NO fix the leak first while you have the trans out, you might have busted the main
lines that run behind the motor, if so they will be a bitch to get to with the tranny in, if its the aux pump worry about it later, you need to figure out where its leaking, we cant tell you that!
there are 2 hose's right above the top of where the tranny mounts to the motor, maybe u hit them.
is the new tranny already back in?
DaveInSaltLake
07-30-2007 03:02 PM
Jason Sowers(rs6's)
04-20-2007 09:58 PM
WOWDee
11-25-2006 06:18 AM
EkSiPd
09-27-2002 10:10 PM
