Question
Question
I get some vibrations through the steering wheel at speed.. usually over 65 mph and gets worse as the speed increases. I think this is because one or more of the wheels are unbalanced. Is there any way of telling which wheel it is, short of taking all of them in to a tire shop?? I would like to be able to just take the wheel off and just take that one wheel in if possible.
Thanks.
Thanks.
could be a bent wheel.
ask em to do a high speed balance on the
wheels.
usually only runs about $10-15 per wheel,
and from that the shop should be able to tell
you if you have bent a wheel.
it does not require taking the tire off the
wheel, so if the shop is reputable, it is
unlikely that your wheels will be scratched/damaged
in any way.
don't be worried about it as long as:
1) you can watch from the customer area.
2) it's a reputable shop.
wheels.
in any way.
Re: Question
When your front tires are out of balance, you will feel it through the steering wheel. When the rears are out of balance, you will feel it more through the seat of your pants.
Increasing vibration? A bent wheel tends to have a speed-specific shimmy.
Take the car in and have a good check done on your
tires, wheels, and perhaps even the suspension and
alignment. In my experience a bent wheel will give
you steering-wheel shimmy at a specific speed (the
60-65 MPH range is notorious) but will stop giving
the shimmy after that. A vibration that continues
to worsen with speed isn't what I have experienced
from several bent wheels in the past.
cosmokitty
NY / NJ / CT Discussion
11-21-2018 11:08 AM
lowbee
Canadian Discussion
11-04-2006 11:55 PM
Alpha6-27Tango(jeff)
10-04-2006 01:50 PM
D Spin
Wheels & Tires Discussion
06-22-2006 10:18 PM
