question about K03 Hybrid turbos
Hybrid is usually created by putting largel compressor wheel. Is the shaft diameter (strength) increased as well?
While the larger compressor wheel allows same boost generated at lower turbo RPM, the load on the shaft is also higher. Any concerns about the shaft longevity?
AudiWorld Expert
I believe k04=5mm, k03=4mm, also the temperature limiter (insulator) has been reduced to allow
more shaft material to strengthen it...
<img src="http://tychl.txf.com/rs4ssg/30.jpg">
AudiWorld Expert
Here's what my search turned up...
<ul><li><a href="https://forums.audiworld.com/s4/msgs/1207961.phtml">https://forums.audiworld.com/s4/msgs/1207961.phtml</a</li></ul>
HIS4
10
11-16-2004 07:36 PM
Imolavirus@BuehnEngineering
11-26-2002 07:57 AM
Minimization
12
05-15-2002 11:09 AM
scoTTish
08-07-2001 09:24 AM
