Question on MAF flows -SlvrBulletS4, Piggie, Darin, anyone?
What is the relationship between torque, g/sec MAF flow and sensor voltage?
I have learned, courtesy SlvrBulletS4, that the voltage maxes out at 5 v and that MAF readings have gone as high as 295-300 g/sec. Is that max reading at 5v or were the K03's maxed out?
If it's 300 g/sec @ 5 v then the relationship is 60 g/sec per volt. Is this correct? Then what is the torque to MAF flow relationship? (I'm too rushed to search for it this morning - somebody must know)
As explained below it's not linear, and as far as relationship to torque...
g/sec is correlated to HP because it is a flow rate over time. But from that you can derive torque. There is a very *rough* guideline that 1 g/sec = 1 wheel HP, which would mean
wheel TQ = (MAF g/sec * 5252) / RPM
Now that is very rough, does not take octane, timing, and air/fuel ratios into account, so by no means is it terribly accurate.
here are some equations i came up with last summer.as MAF rises, the voltage signal to the ecu drops
a 4th order fit based on some low-flow values gave me about a 10% full-scale output error when compared to an observed max of 364.08 g/s. according to this equation, the max flow would be 401.15 at 0 Volts out.
MAF = -0.615*V^4 + 4.4545*V^3 + 14.659*V^2 - 188.43*V +401.15
Fitting data to a minimum of 0 g/s @ 5V, and ~364 g/s @ 0 V...
MAF = 16.669*V^2 - 155.44*V + 363.9
Later,
Mike
Later,
Mike
