Questions on coolant leaks - resevoir was almost empty this morning.
As I pulled the car out of the garage this morning, the coolant light went on in the trip computer. I immediately turned off the car (and haven't turned it back on since) and popped the hood. The resevoir barely had anything left in it. I didn't have time to really look it over, but I think I saw lots of drip marks on the heatshield below it, and the sensor. There's also what appears to be some very small stress cracks in one side of it. There was liquid on the garage floor, but I didn't have time to check if it was water (AC condensation) or coolant. I didn't smell coolant, but I figure that's probably what it is.
The car has 55k miles on it. The last time I checked the fluids was about 3 weeks ago, and a couple weeks before that I had moved the reservoir around while changing the spark plugs.
Think it's just a leaky hose/sensor connection? Should I replace the reservoir? (I'm think yes) How common is it for these things to bust?
YGM concerning the cheaper (and identical) "L" suffix tank that works for the S4! If you want more
info, just search using my username and expansion tank for my prior posting info. Good luck!
DxC
12-03-2007 11:27 AM
araudi47
13
10-25-2005 07:00 PM
SparTTan
9
01-13-2003 05:31 AM
Style12v
10
09-16-2001 08:00 PM
