quick question. is 8x18 ET 45 5/112 , 235/40 R 18 tires too big for us?
Stock is 7.5" wide
Try this. Cannot vouch for accuracy.
<ul><li><a href="http://toy4two.home.mindspring.com/offset.html">Wheel offset calculator</a></li></ul>
It's probably going to rub on the suspension..
I can think of someone who used 18x8 et43 and 235 width tires that did.. so et45 most likely will.. just get some 10mm hubcentric spacers if you really want to run that wheel and you will be fine...
5mm might even be enough..
No way a 235/40-18 will clear the inside upright with an ET45...
...this based on my experiences with 235/40-18's on an ET35. ET40 would be really, really close with S-03's (which are really about a 240 width even though labeled a 235), but probably fine with narrower 235's of another brand.
calculations state
The clearance from stut housing to the inside of the wheel will be 6mm LESS
The outside edge of the wheel will EXTEND an extra 6mm
not sure what this means
Solaris
03-13-2007 11:15 AM
TwentyValveB5+S4
05-24-2006 11:09 PM
d4m0n
17
05-03-2004 03:51 PM
euroman2
09-16-2003 09:36 AM
Boston1.8T
18
03-03-2003 09:29 PM
