radiator drain plug
there's a retaining clip you need to pop off first..it actually slides off just enough so you can
pull the hose off with the clip still on the hose..wiggle it carefully off the radiator neck. try not to bend it too much. use some lube to slip it back on after you inspect that the o-ring is OK
