Re: problem tonight
Re: problem tonight
I have been experiencing bogging when the car is at full throtle. Was wondering if it could be the my GIAC ECU acting up? Also at times check engine light came on flashing. The car have been running ok till tonight. What could it be?
Not necessarily a chip problem. Chips produce more boost, and more boost can
uncover other problems. I had a bad plug that would misfire at anything over 1 bar boost. Easy to blame the chip, when the stock ECU produces less than 1 bar. What are the DTC's?
Re: Not necessarily a chip problem. Chips produce more boost, and more boost can
PaJohn is right. I had identical problem with stock box vs chipped. It turned out to be a hose problem. Dealer pressure checked system and found 2 leakers. Replaced both and problem went away.
Woohoo. Think we've found my starting problem. It's the GIAC chip. Read this for future reference if
TwinTurboTerror
15
08-28-2006 01:08 PM
Billy531
09-21-2003 04:43 PM
turbo-tonyinatlanta
06-30-2002 11:21 AM
