Rear ABS sensor removal
Old Mar 26, 2010 | 05:22 PM
nchiarel's Avatar
Default Rear ABS sensor removal
So I am starting to realize how much the weather has done to my car over the years. This wheel bearing change would take 20 minutes if everything wasn't seized and up. I can not get the rear passenger side ABS sensor out. I tried rotating it but almost snapped the housing. If anyone has run into this problem and knows a good technique let me know. Thanks.
Old Mar 29, 2010 | 09:54 AM
NefMoto's Avatar
I did my rear wheel bearings and abs sensors last week.
Sensors snapped off trying to remove them. Had to drill them out. The bolt holding the sensors in also snapped off. Had to drill the bolts out and retap.
Couldn't get the wheel bearings out with my 6 ton press. Took them to a shop, who needed twenty minutes with a blow torch and a 20 ton press to get them out.
Old Mar 30, 2010 | 06:56 AM
Indyxtype's Avatar
Remove the axle from the upright and you can spray, heat, and tap the sensor from the inside out. Hitting it with spray on both ends and tapping lightly with a hammer and punch from multiple directions should work, if not, add a little heat to the picture.
Old Mar 31, 2010 | 06:32 AM
massboykie's Avatar
Originally Posted by NefMoto
... twenty minutes with a blow torch and a 20 ton press to get them out.
Road salt sucks!
Cheers
Massboykie
dhbiker1
Jan 28, 2012 02:12 PM
BoostFrenzy
Apr 21, 2008 02:58 AM
UKS4APR1
Nov 27, 2007 05:20 PM
gregory_v
May 6, 2007 08:43 PM
Alex42886
Mar 3, 2005 08:47 PM
