Replaced ECT but wondering if I replaced the wrong one?
I recently did the ECT swap. I replaced the one infront of the radiator but when I pulled it out, it was blue and looked slightly different than the green one I bought. Was this the right sensor I pulled or is there another one that I was supposed to change. I've read that there are two but haven't seen any clear info as to which one I was supposed to change.
So should I put the blue one back in? I don't want to screw my car up...
I also read that the after run coolant thermal switch is under the coolant reservoir. Is that correct? I want to replace that one as well so that the after run pump runs more often.
read this...
<ul><li><a href="http://www.modifieda4.com/web/archive/SSP%20198%20-%20Audi%20S4%20Engine%20(english).pdf">it tells you where all the sensors are, and yeah i return to stock what you changed.</a></li></ul>
I may be a bit retarded but that thing is a bit confusing....
It didn't show me where the G62 sensor is located. I showed where the Thermoswitch is (below the coolant reservoir). It also doesn't tell me what sensor I actually removed.
Thanks dude, I was trying to find it in the pages with the front, rear, side engine views....
Hopefully this will finally clear the CEL that keeps coming back.
corne
12v V6 Discussion
07-09-2010 12:22 AM
The Crapple
Audi Original "S" Cars
15
07-13-2006 03:13 PM
cyron
03-15-2005 05:46 AM
hurricanesteve
08-23-2003 01:17 PM
