Replacing cluster with a used cluster
I have a 2000 Tip and bought a used cluster from another 2000 S4 which was a 6sp. The mileage on mine and the one i am purchasing is nearly identical so this part is no big deal. However is the install literally plug and play at this point or is there coding that still needs to be done. Everything that i saw was for installing a NEW cluster so im not sure where to go, any help would be appreciated. Also is there a tut. or how to remove/replace the cluster? Thanks!!!!
Here's a pointer to a tech article on a cluster swap...
...done on a C5 A6. May be of some help to you.<ul><li><a href="https://www.audiworld.com/tech/elec106.shtml">KLICK</a></li></ul>
SloopJohnB@mac.com
07-31-2008 07:00 AM
Texas Twin T
05-18-2006 04:07 AM
