rim help please!
rim help please!
i would like to run 18x9 in the front and 18x10 in the rear. what size tire do i run front and rear. and will having 2 different size width rims mess quattro up in anyway assuming i keep the same rolling diameter front and rear?
thanks
thanks
i have a similar set up....
i am running 245/35 in the rear and 235/35 in the front.....the 245s barely fit in the back....i am on 19 x 8.5 up front and 19 x 9.5 in back..the width difference is no biggie, as long as the diameter of the wheel and tires are the same.... ie: porsche...they run staggered also on thier AWD cars as well.....
good luck
good luck
18x9 and 18x10 !!!
Jeeze, and my 18x8.5's with 245/40's don't fit (see link below). Can't imagine you'd get rims that big under a stock body.<ul><li><a href="https://forums.audiworld.com/s4/msgs/391278.phtml">https://forums.audiworld.com/s4/msgs/391278.phtml</a</li></ul>
