Rob O - here's the close ups of the camera mount to show the flexibility in mounting options...
AudiWorld Expert
<img src="http://ctny.audiworld.com/mark/s4/cameramount/dsc01730.jpg">
<img src="http://ctny.audiworld.com/mark/s4/cameramount/dsc01732.jpg">
<img src="http://ctny.audiworld.com/mark/s4/cameramount/dsc01733.jpg">
<img src="http://ctny.audiworld.com/mark/s4/cameramount/dsc01735.jpg">
<img src="http://ctny.audiworld.com/mark/s4/cameramount/dsc01736.jpg">
base connector swivels - see above and below photos
<img src="http://ctny.audiworld.com/mark/s4/cameramount/dsc01737.jpg">
<img src="http://ctny.audiworld.com/mark/s4/cameramount/dsc01738.jpg">
<img src="http://ctny.audiworld.com/mark/s4/cameramount/dsc01739.jpg">
Camera attachment even on a ball joint to angle to one side or the other:
<img src="http://ctny.audiworld.com/mark/s4/cameramount/dsc01741.jpg">
<img src="http://ctny.audiworld.com/mark/s4/cameramount/dsc01742.jpg">
Imagaine it on the windshield like this - plenty of room around the camera connector to fit a camera with a large base:
<img src="http://ctny.audiworld.com/mark/s4/cameramount/dsc01743.jpg"><ul><li><a href="https://forums.audiworld.com/s4/msgs/1966838.phtml">Original post</a></li></ul>
Cool ... thanks.
Does it have a pretty good grip when glass mounted? The guy who posted photos from his 20D was using the 6-cup version.
Definitely going to give one of these a go.
AudiWorld Expert
yeah, good grip...
while I cringe at the thought of having any camera, with any mount, on the outside of my car, this one seems pretty stable (inside). I just weighed my camera and it comes in at 1.6lbs. Somewhere on that site, I think they show one of the suction cup mounts holding 75lbs. Ok, I just stuck mine to my dishwasher (I started at the bathroom mirror but quickly realized I would probably rip it off the wall), and I started to deform the front face of the washer before I could pull it off. I now feel much more confident that no little sub-2lb camera is going to pull this off of a window. For security, I'd think the 3-cup is sufficient. For extra stability, you might opt for the 6 cup. I noticed that any vibration/flex in the mount is due to the suction cups being made of rubber/plastic. If you had 3 more, that were spread out by a distance (as the Ultra is), it would help with any pivoting/flex at the suction cup to window connection. This flex is amplified if you have a heavier camera, and/or position the arm extended all the way out to one side [torque = force(product of mass) times distance(from pivot)]. And the ultra is only $13 more. It doesn't look all that easy to convert it back to a 3-cup as the lowest ball mount is rivoted to that small triangle plate (on mine). It would just mean drilling out the rivot and putting a new one (or bolt) in it's place.
Anyway, now after putting some serious human force on this thing, I'm probably going to go take some camera-outside-of-car footage as I feel pretty safe now. I'll be sure to add a tether just in case (so that way the $1000 camera causes $2000 in paint damage to my car)
AudiWorld Expert
Yeah, I found that a bit confusing at first. The bold red letters begin each package....
I'll see if I can help...
<b>ChaseCam Triple Cup Suction Mount</b>
This one has 3 packages under this common name:
1.) $40 - 3cups w/ camera connection
<img src="http://chasecam.com/mounts/triplecup.jpg">
2.) $60 - 3cups w/ camera connection & interchangeable clamp base
<img src="http://chasecam.com/mounts/triplecup-clamp.jpg">
3.) $70 - 3cups w/ camera connection & clamp base w/ camera conection
<img src="http://chasecam.com/mounts/triplecup-clamp-both.jpg">
Next up is:
<b>Camcorder Window Mount</b>
This is like #1 above (3cups) but also includes the extension and associated connectors to the extension.
$65
<img src="http://chasecam.com/mounts/wm-front.jpg">
<b>ChaseCam Ultra Mounts</b>
$78 - 6cups, no extension:
<img src="http://chasecam.com/mount/ultramount-sm.jpg">
<b>ChaseCam Ultra Window Mount</b>
$99 - 6cups, with an extension:
<img src="http://chasecam.com/mount/ultrawindow-sm.jpg"><ul><li><a href="http://chasecam.com/mounts-suction.htm">http://chasecam.com/mounts-suction.htm</a</li></ul>
Next up is:
$65
LOL to your last line ... that's what I was thinking *exactly*! Too funny.
I'd definitely tether my setup as well, but my first thought is "now if the camera comes loose, it'll bang into the paint on the car." LOL. I think, in the end, I'd rather try and get home owner's coverage of a broken camera for a couple grand than have to have bodywork done. ;-)
Thanks for the extra info. My DSLR setup is considerably heavier, probably closer to 7 or 8 lbs with wide-angle zoom lens mounted. Still not sure if the version you have or the Ultra (6-cup) would work better.
