RS4 Mesh Conversion Progress ... pictures and questions inside ...
#13
Jason YGM. Those are OEM centers, from the same shipment as the mesh we just did ....
the conversion on our shop car with. That is really weird, maybe you can stop by sometime....?
#18
i'll take pics of mine tomorrow... but that's how mine looked
when i was setting them up. Because you removed the centre bar it's less rigid. Set the mesh in the frame so the black edge is "inside" the frame. Then fasten it using tape temporarily... glue one side at a time. In my case i just drilled small holes and zip tied it using the little tabs that are already on the mesh. You can't tell unless you go right up to it.
#19
Pictures would be cool, just to make sure I'm on the right track ...
Also, thanks to everyone for their input ...
My issue was I followed a DIY in the tech area, however, that guy used some metal mesh, and I'm using OEM RS4 stuff ...
Didn't know I needed the old 'frame' from the old inserts ... and unfortunately, cut the tabs off that mount them. O well, just more glue I suppose.
Just FYI for other attempting this mod ...
It's gonna rock when it's done!
Thanks again Brian at Avalon for the RS4 Mesh ...
-chimchim
-chimchim
