S4/A6 2.7T Tiptronic technical data
Guest
Posts: n/a
I contacted ZF Getriebe GmbH for information on the 5 HP 24 tiptronic transmission they supply for the S4 and A6 2.7T. The Tip in these cars is a 5-speed auto transmission with integrated center torsen differential and a front axle differential.
The Tip can handle 308 hp and 310 ft-lbs. They show 313 HP, but that doesn't follow the math I used:
HP = kW x 1.341
ft-lbs = Nm x .73756
Doesn't look like the Tip will be able to handle a chip upgrade with it only rated for 310 ft-lbs, but my A4 Tip is only rated for 228 ft-lbs and it seems to handle the PES with 265 ft-lbs with no trouble so far.
Transmission capacity:
T(max) Engine at 3500 rpm = 420 Nm
P(max) at 5500 rpm = 230 kW (313 HP)
n(max) in 1st to 4th gear = 7200 rpm
n(max) in 5th gear = 6200 rpm
n(max) KD shift = 7000 rpm
T(max) Turbine foward/reverse = 800 Nm/500 Nm
Converter:
W 260 S with 2 controlled converter clutches
T(p) = 78 -281 Nm at n(p) = 2000 rpm
Ratios:
1st gear 3.57
2nd gear 2.20
3rd gear 1.51
4th gear 1.00
5th gear 0.80
Rev. gear 4.10
Constant 2.63 ... 3.73
Weight with oil 141.1 kg
NeilM<ul><li><a href="http://www.a4.org/bbs/archive/9807x4/messages/474.shtml">A4 Tiptronic technical data</a></li></ul>
HP = kW x 1.341
Converter:
Ratios:
1st gear 3.57
2nd gear 2.20
3rd gear 1.51
4th gear 1.00
5th gear 0.80
Rev. gear 4.10
Guest
Posts: n/a
Re: S4/A6 2.7T Tiptronic technical data
Thanks for the research. I plan to have my S4 Tip chipped stage one and this is comforting to know that it will be "strong enough" for the increase. Thanks again this is a good example how this board services we the buyer.
jslerner
02-25-2001 10:50 AM
