Samco TBB from AWE going in tonight...any pointers, tips, suggestions out there? TIA.
Old 02-17-2006, 06:54 AM
Jms3's Avatar
Default Samco TBB from AWE going in tonight...any pointers, tips, suggestions out there? TIA.
I hope to avoid the VandyS4 install experience.
Old 02-17-2006, 06:58 AM
Member
S4Poor@Curbside's Avatar
Default Loosen the Bi-pipe screw on each side, buy industrial zip ties or new clamps,
cut the top of the sensor hole so the sensor doesn't stick up so high, that way (if you want it) you can put the front cover back on. Don't drop anything in the TB. That should be about it. I got it down in 15-20 min' for my first time. Super easy DIY.
M3KILR's Avatar
don't drop anything in that blackhole called the engine bay
Old 02-17-2006, 07:00 AM
lemieux@curbside's Avatar
Default i got a good tip for ya :
sell it and get couple new STOCK TBB-s and use the stock clamps .
or if you really want to use the samco get new clamps the seal well (use the stock clamp for the tbb-tb side).<ul><li><a href="https://forums.audiworld.com/s4/msgs/2198410.phtml">https://forums.audiworld.com/s4/msgs/2198410.phtml</a</li></ul>
Old 02-17-2006, 07:05 AM
AudiWorld Expert
Captain Matt, I be's Avatar
how do industrial zipties hold up to heat cycles?
Old 02-17-2006, 07:09 AM
Member
Default So far, so good. I wouldn't suggest the HD or Auto part store kind, but
good quality (police hand cuff style)are very strong and thick. I've been using them on the TBB, and DV's for about 3K-4K miles. Much easier for taking on and off too. Cut, and replace w/ new ones.
Old 02-17-2006, 07:11 AM
AudiWorld Expert
and DONT DONT DONT drop anything into the charge pipes while the TBB is off.
Old 02-17-2006, 07:38 AM
New Member
PorpShow's Avatar
or into the Timing belt cover right below the TBB...ask me how I know...
Old 02-17-2006, 07:43 AM
Jms3's Avatar
Virtually unpossible for me to avoid.
Old 02-17-2006, 07:46 AM
Jms3's Avatar
Cutting the sensor hole: is this pretty self explanatory once I get in there?
Quick Reply: Samco TBB from AWE going in tonight...any pointers, tips, suggestions out there? TIA.
