Stage 3 Not Holding Boost
I posted a month or so back about buying a stage 3 s4. To make a long story short, I bought it, love the car, but last week it started not holding as much boost as it was.
According to my boost gauge, I was getting 20psi or so and now I am getting 15 or 16. If I really get on it it will max out around 18 and then go back down to 15 or so. I read up on the problem, and checked the TBB (no problems there) and in the process found a cracked vacume hose going to the driver's side DV, which I replaced but am still having the problem.
I am not driving it at the moment since I managed to get my truck running, but I need to get this fixed while I am on vacation and have time to work on it. Has anyone had the same problem or have any suggestions as to what all I should look at? F-hose maybe? Should I track down a pressure tester?
agree with the pressure test - also, which stage III is it - kit or homebrew?.....
When you got the car, was it 60 degrees outside and now 10F?
Just curious because temp changes can make a difference - not sure if that much of a difference though.
Do a pressure test and report back.
denic992-- JAYHAWK
15
03-22-2007 09:08 AM
Help!First time boost gauge. Boost reads 17 in vacuum at idel and 18 psi at full boost. AMS Stage II
Aldonis
10-21-2006 01:09 PM
back2black
03-17-2004 10:51 AM
