Stage 3 pricing?
Stage 3 pricing?
Well, summer is over and winter is here. Which only means one thing - summer is right around the corner.
The goal, at least, for next summer is to go stage 3 in Miss. Santorin. I'm thinking about going with the FrankenTurbo F4H-BT turbos ($2,000 total with K04 inlets) and VAST fueling kit ($1,700). I have a couple questions, though...
1) Is it possible to go stage 3 for less than $4,000? I'm hoping to be able to find a used fueling kit (I'd also consider APR if I were going used), which goes for about $1,000, sometimes less. If I could find a used set of turbos, so be it, but I'll most likely end up buying them new.
2) Besides turbos and fueling, what else should I also think about purchasing? I'm not going to be pushing more than 450hp, so I don't plan on upgrading the clutch, but if it's recommended, I'll look into it. I already have an upgraded ECU, picking up my exhaust (SSAC most likely) when I get back home for Christmas break, but what else am I missing?
3) For those that have done it themselves, how easy is it to install the "kit" yourself? I'd probably have it tuned professionally afterward (if I do the install myself), how much will that cost roughly? Also, roughly how much does it cost to have someone install it for me if I bring them the parts (for those that have had a shop do the work)?
Help me get prepared for stage 3!
I'm going to save you a little bit of flaming and point you to the many technical threads based on stage III tuning on this site.
I see this is your first post, which of course, everyone has. However, you should use this site as a resource. All of the information you could ever want on tuning, turbo choices, supporting modifications and pricing can be found within the search function.
Check out Audizine and Quattroworld as well.
PS - Factor in a clutch. Trust me. You'll wind up stranded. Pulling off a sold stage III setup for less than $4000 is going to be difficult.
aamirs4
28
03-02-2008 08:54 PM
S4Fish
17
02-06-2006 07:01 PM
jzkbbi
05-29-2003 02:24 PM
naptownnogaro
17
03-13-2003 02:38 PM
