Start up Idle RPMS question.
Old 07-26-2003, 01:03 PM
New Member
SilS4's Avatar
Default Start up Idle RPMS question.
My car has about 52000 miles on it now. Something I recently started to notice was after not driving my car for about 6 hours (eg - when I get up in the morning to go to work) the car will idle at 1500 RPMS for about a minute or two. Then, it will seem to slowly drop to about 750 which is where my car has always seemed to idle before now.
Also, when I drive the car between where it normally idles (750 RPM) and the mysterious idle speed (1500 RPM) the car seems to have very little boost if any.
Anyone had this problem before?
My dealer is fairly unhelpful when I bring my car in anymore, so I would like to give them a little direction to try and find out why this idle RPM is so high. Any pointers/suggestions would be helpfull.
Thanks..
Old 07-26-2003, 01:04 PM
AudiWorld Expert
mpwolf's Avatar
Default Any VAG codes? It could be a vacuum leak. However, the car always idles high when started cold to
warm the catalysts quickly. It should have done this from the start.
Old 07-26-2003, 01:07 PM
New Member
SilS4's Avatar
Default No VAG codes and..
My car, until recently, ALWAYS idled at about 750 RPMS. I have talked to the service people at my dealership about the problem and they said they couldn't find anything except for a MAF was a little out of spec. So, they replaced that but I still have the problem..
Old 07-26-2003, 01:15 PM
AudiWorld Expert
mpwolf's Avatar
So, even when cold, your car always idled at 750 from the start?
Old 07-26-2003, 01:18 PM
New Member
SilS4's Avatar
Default Yes, Until about 46000 miles..
At about 46000 miles it started idling at 1500 RPMS when started cold. Before that, it always idled at about 750 when started cold.
Old 07-26-2003, 01:29 PM
AudiWorld Expert
mpwolf's Avatar
Default That's strange, every car I've ever owned has idled high when cold. Anyway, check for a vacuum
leak, that can lead to a handful of problems.
Old 07-26-2003, 01:43 PM
Elder Member
George @ BostonAudi's Avatar
Default Thats not that unusual, a lot of cars do that to heat up the precats faster...
Not great for the engine, but significantly reduces emissions.
1500rpm is a tad high, most S4's I've seen do more like 1200rpm, but I wouldn't be freaking out if I saw that on my car.
Old 07-26-2003, 03:45 PM
Elder Member
DocSlow (Mini Pig)'s Avatar
Default Nobody has boost between 750-1500 rpm, so that is no problem...
I idle aroun 1,000 and go down to about 800 rpm. It is normal to go down as the car warms up, but I don't know about starting at 1500!?
Old 07-26-2003, 06:11 PM
CatOne's Avatar
Default Back in the day, that was called the "choke."
When the car is cold, it will idle higher. That's to get it warmed up and not have it die when it's a bit tougher to turn over.
How old are you? Must be less than 22 ;-)
Plus... no boost at < 1500 RPM is totally normal... you need air getting to those turbos to spool them up, and at 800 RPM you don't have it. NEVER floor it at 800 RPM FYI... it's hard on parts.
Old 07-27-2003, 09:28 AM
Elder Member
S4mig@PEB tuning's Avatar
Default Do you get EPC's also? more
I had a problem with idling at 1100 rpm when cold, and I was getting EPC light quite often which always put me limp mode. Vagging it came back with "Throttle actuation potentiometer range/performance" If you dont have any EPC's yet, I'm willing to bet you'll start getting them soon as it took about 2 weeks for them to pop up in my car after i first noticed the high idle.
I took it to the dealer and they ended up replacing the potentiometer if im not mistaken. Quick fix for them but my service manager told me they still billed AoA for $1200 dollars of work. Now I also had my BPV's done at the same time though which shouldnt have been long, most of the time I imagine was finding the problem as they orginally wanted to replace my entire throttle body. Hope this helps you out.
BrianG
04-01-2007 09:47 PM
90qt
12-14-2004 08:59 PM
audilong
10-29-2003 05:37 PM
audilong
10-15-2003 06:28 PM
G_Factor
07-07-2002 10:07 PM
Quick Reply: Start up Idle RPMS question.
