STFA'd and need the part number for a PCV please. TIA!
Also what is the part directly off to the right on the y-pipe? I think that needs to be replaced as well. Got a slight oil smell and no leaks.
Thanks.
Thanks.
Per the self-study guide, that is the "pressure limiting valve"...
Opens under boost to direct crankcase vapors into the y-pipe (which is where the oily residue in the intake comes from).
I'm pretty sure its not a part by itself but is integrated with the whole spider hose assembly off of the back of the manifold.
-Dave Pramanik
-Dave Pramanik
STFA!!!
This one is for the 2000-2001 manifold though. :P
-Dave Pramanik<ul><li><a href="https://forums.audiworld.com/s4/msgs/1805034.phtml">https://forums.audiworld.com/s4/msgs/1805034.phtml</a</li></ul>
Aw h3ll! Damn. I looked, I swear I didn't see that...
Thanks, you are a god as always. Mine is an 01.5
Think it will work? I have a place to start though. Have you replaced yours?
I haven't replaced mine. The '01.5 is different because it doesn't have the F-hose and has a ...
connection to the MAF accordian hose which the '00 and '01 S4s lack. However, I'm guessing it'll be one of the other parts with same prefix and just a different letter at the end.
-Dave Pramanik<ul><li><a href="http://www.impexfap.com/partlist.cfm?getpart=74929&PARTNUMBERSEARCH=07 8%20103%20235#part74929">http://www.impexfap.com/partlist.cfm?getpart=74929&PARTNUMBERSEARCH=07 8%20103%20235#part74929</a</li></ul>
