STG 3!! Installed... questions please ... TIA
Just did a timing belt today and installed the rest of my goodies.
At the same time I installed the following.
RS4 Injectors
RS4 Maf Accordian hose
Custom milled Tantrumwerks 85mm Maf housing (Bosch)
Vast 5 bar fpr
Previously installed:
RS4 Turbos K04
Bipipe
Labree Tantrumwerks downpipes and full exhaust
EVO CAI
Boost controller set at 1.4 bar peak.
Car builds boost and peaks at 1.4 bar then tapers down to .9 bar to redline. Is this normal?
Car feels great, runs strong except for cyl 3 misfiring.
RS4 Injectors
Vast 5 bar fpr
RS4 Turbos K04
Bipipe
EVO CAI
What kind of software?
And no, the taper down to .9 bar is not normal. I'd start by pressure testing the intake tract and checking for codes. Also wouldn't hurt to check what the DC is set for at high RPMs in your EBC.
GIAC X pump software on A box.
I'm misfiring in cyl 3. going to check the seat on the injector. Wasn't a problem before the install so I bet it's just a loose plug or something.
Sorry, but I ASSumed you had an EBC based on your "Boost controller set at 1.4 bar peak" comment.
I've yet to find a MBC that allowed you to set your boost to a certain peak number. Mine dynamically changes with weather.
manually set mbc to 1.4 bar
boost at WOT climbs to 1.4... then tapers down to 1.2 then settles at about .9 bar at about 6500 rpm.
Not running a map clamp (TCD). Cyl 3 is misfiring like a bish... no idea what is wrong. I just went in there and tightened all the hoses and clamps again and made sure all injectors are seated properly.
Any ideas on why I'm misfiring?
Any thoughts would be much appreciated.
