Stoptechs - how many hours to install? - cost for install, including brake lines - warranty issues?
I'm thinking of getting the kit. I just wanted to know how much more than the $2,000 (parts) I'll spend to put them on and will the dealer have issues with ABS and ESP and XYZ?
DIY, I've done 3, takes 2.5 hrs with a small brake and is easy OR
you can pay a shop, for like 3+ hours and be out some 225_ bucks.
have the shop do the brake fluid flush for like 50 bucks, warranty issue?
you just spent 2K on brakes, no waranty but then again after 5 track events, these things are AMAZING!
Re: Stoptechs - how many hours to install? - cost for install, including brake lines - warranty issu
I can sell you my used Stoptech kit (4000 miles no track time) for $1200. Rotors are like new.
dual 2 piece rotors with Red calipers and 2 front stainless braided lines.
It takes less time if you put the pads into the calipers first. I find that the locking pins for the pads are harder tp put on once the caliper are bolted on.
Rear stainless is a must (helps balance bias) NO on the rear rotors.
there isn't a kit out there that I am aware of that does rear brakes for the S4 and also the kit was designed for JUST the Fronts.
good luck!
good luck!
Small Town Terrorist
03-21-2008 04:42 AM
Boston Driver
17
03-28-2006 11:55 AM
deml0
9
07-07-2005 04:39 AM
Stätus Josh
05-26-2004 09:17 PM
PGTT
12
03-27-2001 11:26 AM
