Strange Clutch issue with my Stage 4 CM and LWFW.......
When I hammer it in 1st and second gear the clutch does not return all the way up, then I have to pull it up the 1 or 2 inches with my foo, and then the engagement point seems like it gets lower, since the CM PP does not have the SAC anymore what would be causing this to happen??
Any ideas welcome!
Any ideas welcome!
check your brakefluid level so you dont run out of it if the clutch line leaks.
BTW. if it leaks you might need the pull the engine to replace the line : (
It might also be bad slave syl.
Zsolt
10-30-2008 07:30 AM
gutefahrt
09-10-2008 06:17 PM
MySTG3S4
13
12-04-2007 12:48 PM
SchagenWagen
02-17-2004 05:01 AM
