Is there any reason why I SHOULDN'T get the Avant-specific H&R coilovers for my sedan?
AudiWorld Expert
The rear spring rate is 25 lbs. higher on the Avant coilover than on the sedan. I'm thinking that will help to curb understeer a little bit better than the 450/450 spring rates on the sedan-specific coil-overs. Is there any reason I shouldn't do this?
you logic is sound. get the avant ones.
you may still want to add the 19mm rear sway on soft.
25 lbs more in the back won't promote oversteer...
it means *a little less* understeer...but the car will still understeer!
My car has 100 lbs high spring rate in the back, and as near as I can tell (fiddling on on ramps in the wet) it's pretty well balanced.
