Was there ever a revised manifold between 2000-2001?
No...the TIP I believe was run all years and has the plugs in the back for..
plug and play for earlier models of the 2000-2001 to update and delete the F-hose and other little vacuum hoses. The fuel rail also changed a little bit where the t-line is where the DV's vacuum hose hooks up (old is hose to plastic T, new is solid fuel rail up to T). The updated 6 spd. manifold takes some modification to make it work on the older 2000-2001's to plug in all the hoses. I'm not sure EXACTLY what...The main purpose of updating is though for deletion of F-hose and the intake runners are longer and have better flow. Email Piggie and he can give you more definate explanation...
Can someone tell what those hose that connects to the F-hose and runs under the intake manifold is??
mullarks
12
01-12-2004 11:44 AM
