Is there a solution for rear diff crashes on hard launches?
Two options...
(1) Stiffen the rear diff mount. I did this using cut up urethane bushings wedged in it to dampen the movement. Worked great but transmitted additional vibration to the cabin.
(2) Replace the rear diff mount. I had this done under warranty when I was unhappy with the vibration from fix #1 and it has been fine since.
If it becomes a problem again, I'll look into less intrusive methods of repair.
-Dave Pramanik
-Dave Pramanik
when they replaced the one mount did they replace the other two as well.....
there are 3 mounts up there and as with mine only one is worn out but im sure the others are on their way. Im having all 3 replaced at the same time
AudiWorld Expert
Any idea what the typical lifespan of the rear diff mount is?
Car only has about 50k on it right now. If I replace the mount now and keep on abusing it, any idea when I'll have to replace it next?
Also, how much of a PITA is this to replace?
