Those with Grooved Bilsteins....
What grooves are you running? I am going to attempt to adjust mine today and would like to know what grooves others are running and what ride height it gives them. I am using the MTM/Eibach combo and want it a bit lower. I do not remember what it was set at now but I will find out when I remove them.
I'm using H&R Race w/ Grooved Bilsteins... set on the tallest ride height.
Bouncy as hell, I need to drop it back down to the middle setting. Keep in mind that at different heights the springs and shocks may be not as efficient as they should be.
I went to highest setting because of rubbing after Eibach started to settle.
Still have it set at the highest setting after going to the stiffer MTM/Eibach springs.
Can't recall the height but I beleive it's around 25.5" on all four corners?
Also, wheel size and tire size will impact this as well.
In my case, I have 18x8 OZ Sls with Kuhmo 712s in the 225 size. The tires will have different heights even in the same sizes.
bl97
12
09-23-2002 05:40 PM
Vicarious
02-09-2002 06:46 AM
SmellsSoS4lmon
17
06-20-2001 04:01 PM
