timing belt failure after 2000 miles :(
Old 01-04-2006, 02:08 PM
New Member
PorpShow's Avatar
Default timing belt failure after 2000 miles :(
so, i've driven less than 2000 miles since a complete timing belt/pulleys/pumps replacement. On the way to work, engine died. Crank it over a bit...sounds like no compression !@#$...pop the hood and pry open belt cover, loose timing belt.
Before i get it apart and know what failed, anyone wanna place bets?
Old 01-04-2006, 02:10 PM
P. Bauer's Avatar
tensioner
Old 01-04-2006, 02:15 PM
wagongotya's Avatar
2nd
Old 01-04-2006, 02:25 PM
FixedWing's Avatar
Default No other symptoms?
If it failed within 2000 miles of the change then you can bet either a defective replacement part or a mistake on the install.
Not good news, sorry. :-/
Stephen
Old 01-04-2006, 02:35 PM
LanceEagle's Avatar
Default Did it make any sounds just before it died?
Who did the TB job? Did you replace the hydro-tensioner along with the eccentric tensioner? If you did the work: Did you get both washers off the old ecc. tensioner and put both of the new washers on the new tensioner? Sometimes the old washer will stick to the side of the block, which can make its way onto the crank sprocket. Is the belt chewed up at all?
Old 01-04-2006, 02:40 PM
Banned
Mat Indukts Lambos's Avatar
Default Here's a big raised eyebrow for you......
I've got about 3000 on my recently built engine, which got all new timing belt parts, save one: the hydraulic piston that applies the force to the tensioner roller for the timing belt.
So, my symptoms were a temp gauge that creeped slightly over normal at idle, and under varied conditions, I could hear some belt noise from the engine.
I took it apart last weekend, and found I could spin my waterpump by hand, and the belt was a bit loose. Ironic. But no damage, I thankfully figured it out before that happened.
Sorry for your misfortune Porpshow, I've seen a few situations like yours. Most common was an overtorqued allen bolt holding the tensioner roller. It makes them stretch, and they snap after some heat cycles.
Old 01-04-2006, 02:46 PM
Arcteryx::Stock Rods's Avatar
3rd
Old 01-04-2006, 04:42 PM
New Member
Phoenix33759's Avatar
Default agreed...most premature t-belt failure is due to overtorqued bolt for tensioner
who did the install???
Old 01-04-2006, 04:55 PM
Rest In Peace
O.W. Kenobi's Avatar
Great. Now everyone will advocate for 1500 mile intervals. :-/
Old 01-04-2006, 06:12 PM
New Member
evan@absolute's Avatar
I'll say pump if you used an off brand
tebit
01-05-2013 05:24 AM
dddvorak
30v V6 Discussion
03-12-2009 09:08 AM
GPZ
11-17-2006 04:13 AM
paudibert
Audi 100 / A6 (C4 Platform)
10-06-2005 12:36 AM
Zamore
12-21-2004 06:41 AM
Quick Reply: timing belt failure after 2000 miles :(
