Tiptronic shift cover: brushed aluminum project *what i did this weekend* LONG&Detailed
Introduction:
Well, basically my shift cover has been bugging me for the past few months since I got the S4, because it has some scratches that run down it on all sides. It's not worth buying a whole new shift cover which the dealer quoted me at 400 something because of the electronics that are attached to it. So i decided to try to fix it myself. For the most part I had no guide to follow, so I made some mistakes as I will explain later.
Materials required: Some masking tape, Sandpaper. 3 different grits, grit 150 to take off the chrome paint, grit 220 to smooth the lines, grit 320 to fine tune your brushed aluminum look.
1. The first step was to remove the shift plate cover that surrounds the shifter. This was achieved by just pulling up at the back side of the cover, give it a hard pull and it should pop off. then pull back and over the shifter and voila, its off.
<img src="http://pictureposter.audiworld.com/85331/dsc01136.jpg">
2. Next you will see that the shift plate cover is secured by 4 locks, 2 on each side as you can see in the picture above, they look like tabs sticking out from the sides, it will be pretty obvious when you pull off the cover. You will need to unhook these clips, but be very careful, they are extremely fragile.
*This is where my first mistake was, I managed to break one of my clips on the first try, it just kinda folded and broke off. So i thought, Oh well, might as well break off all 4 and find another way to secure the plate when I reinstall.
Upon breaking all 4 clips i was suprised to find that the shift plate was snugly secured in its place still. This is because of the adhesive that was holding the plate down, which was friggen strong! So i pulled up and slowly pulled it off the adhesive and it came off, which is where i took the picture above.
3. Upon loosening the shift cover I noticed that there was a cable attached underneath. This is for the leds, you must disconnect this from the underside. There is a pressure release on the side of the plug as shown here
<img src="http://pictureposter.audiworld.com/85331/dsc01140.jpg">
4. The next step in getting the plate off, is to put in the keys, but dont start the car, and shift it into 3rd gear like the pic below. This is so the shifter is in an easier position for you to work with.
<img src="http://pictureposter.audiworld.com/85331/dsc01145.jpg">
5. there will be a metallic boot (cylinder) that sits below the shifter ****. Pull this down, and it should pop down.
<img src="http://pictureposter.audiworld.com/85331/dsc01147.jpg">
6. upon pulling it down, you should see where the shifter clamps down on the rod with its teeth. Now mine didn't have a ring around it to hold pressure (wtf?) but if yours does, use a tool to pry it down and off the ***** clips. Even though mine didnt have the ring in it. I found it to be extremely secure.
7. Now go up to the Button on the shifter ****, and slowly pull it out, until you feel a gap underneath it. Then secure it by putting something in the gap so the button does not release and go back into the ****. The reason for this is because when the button is fully pulled out, its not holding onto the lever inside the shifter. Only when you have done this you can pull off the shifter ****.
8. Pulling off the shifter **** was a pain in the ***. I personally used the "Close your eyes, and PULL!!!" technique. Just make sure your button is pulled all the way out and secured.
<img src="http://pictureposter.audiworld.com/85331/dsc01149.jpg">
*ok got it off, and nearly punched myself in the face.
9. Aww man, My tape that was holding the button out fell off, and my button is now stuck all the way depressed!! and i cant seem to pull it back out.
<img src="http://pictureposter.audiworld.com/85331/dsc01150.jpg">
*no worries, just take some masking tape and put it lengthwise accross the button as much as possible. Use this to gain grip and just pull the button out slowly. Then secure the gap underneath with a piece of tape or something.
10. Now that you have gotten the **** off, you can take off the plate. Gather your supplies and the plate and head into your home, this is where the hard part starts...
*you may notice that you cant pull out your keys in third gear, just pull up on the levvy where the shift **** use to stand, and that simulates the button being pressed, then shift into park and grab your keys.
11. Now that youve got your supplies, You need your sandpaper.
<img src="http://pictureposter.audiworld.com/85331/dsc01151.jpg">
*This is where I made my second mistake, and it was pretty bad, I didn't know you can take out the Black panel underneath the aluminum shift cover, so i began sanding with just some tape to cover the little hole buttons with the letters on them. Well, long story short, i ended up messing them up pretty bad, and sanding and scratching the letters off on some.
I HIGHLY URGE YOU TO REMOVE THE BLACK UNDER-PLASTIC w/ Button Letters before you begin sanding, or else you will end up like me.
12. To remove, take a paper towel, and something that you can use to poke, I used a wooden chopstick but you can use anything, put the papertowel over the plate, and with your chopstick push down over the papertowel where the first hole is where the "P" (for parking) is, dont be scared, push hard until you hear the adhesive being removed. THe paper towel is so that you wont scratch up these little black inlays. Repeat this process over the other holes, until you have loosened the under-black-plastic portion of the shift cover, then remove it w/ the electronics board.
13. Begin sanding
<img src="http://pictureposter.audiworld.com/85331/dsc01153.jpg">
*note: as you can see i didnt do the tip above, and just taped over my inlays, i scratched them up pretty bad and just ended up scrapping the whole thing as you will see later.
Start with the 150 grit and remove all the chrome paint. ITs ok to sand it all crazily, the grain doesnt have to be set yet.
Then use the 220 grit, and make sure you only sand in a Top to Down stroke motion, this gives it the brushed aluminum fine grain look.
Then use the 330 and refine the look, and smooth it out, also only stroke in an up down motion to give it its "lines".
When you are done, it should look something like this:
<img src="http://pictureposter.audiworld.com/85331/dsc01161.jpg">
Ah it looks pretty good, way better than the chrome with the scratches in it, in my opinion.
Get it as flush as you want, then rinse it off, and look at it and marvel at how much better it looks. Then its time to reassemble.
14. Use some masking tape and put it all together, and make sure its secure. At first I used a hot glue gun, but its not recommended. It got all messy and I cleaned it up and decided to go with tape, No one will see this underside anyway
*Note, I didnt have the under black plastic inlay piece anymore because I Fux0red mine all up, so I went with the Glowing Red LED effect and just didnt use it.
<img src="http://pictureposter.audiworld.com/85331/dsc01162.jpg">
^^^ OWNED!!!! i'm just going to throw it away. see how my buttons are all scratched off? well i sanded it down even more, thinking i could save it, and work something out with it. Nope, its trash.
I just taped my circuit board and the black plastic lining to my shift cover and reinstalled it that way.
15. Reinstall everything, back tracking the way how you took it off.
Note: When installing the shift ****, make sure your Shift **** button is completely Pulled out again while you push it in.
END RESULT. FINISHED PRODUCT ***********
<img src="http://pictureposter.audiworld.com/85331/dsc01165.jpg">
<img src="http://pictureposter.audiworld.com/85331/dsc01170.jpg">
<img src="http://pictureposter.audiworld.com/85331/dsc01172.jpg">
It looks pretty good without the plastic inlay piece, because the Leds are in full glow and they really shine out. looks kinda high tech. Of course, yours will look different if you didnt *** UP your inlay piece like i did. But overall i still think it looks good (if not cooler, for the ricer's taste JK) without the piece, except that I have to look at my Dash menu to figure out what gear i'm in :P. No more scratches, A cool brushed aluminum cover that is flush, I'm HAPPY!
13. Begin sanding
wow. looks really nice. I am kicking myself for not going that route originally...
take some pictures during the day. I would love to see the brush grains.
Good job other than botching the LED cut outs. How much are they going to charge you for that piece?
Re: wow. looks really nice. I am kicking myself for not going that route originally...
Thanks AN, Dunno if they sell that piece individually, my guess is if i want that piece, i'm going to have to buy the whole system, which they quoted me at 400$ something dollars. I asked just for the top Chrome cover, and they said they dont sell that separate.
Oh yeah, i think that was my step 1, but i didnt have a picture for it. and..
yeah, i know my plate cover wasn't that bad (the camera shot kinda hid some of the bigger scratches). But nontheless, it gave me the opportunity for a cool DIY project!
looks really nice!
i did that to my first quattro badge on the trim...you might want to do that too (so it matches).
now you just need to let me cover the rest of your shifter plate in CF :-)
That will be my next project. Kinda hard though, thought about it...
but i couldnt take it out of the ****, and it was a major PITA to keep it extended while trying to sand it. I didn't want to start something that i couldn't finish.
