Toulene...who's using it?
Have any of you guys been using toulene with pump gas? If so, how long? Im trying to get a grasp if there are any negative long term effects of using toulene. I would probably mix with 93 octane to obtain 98-100 octane rating.
thx
thx
I have been for 1.5 years now with no problems. Just hard to start in the AM if it is cold outside.
Also used loled Avgas for 1 year with no problems before I found the toulene. Just becareful because once you use it, you will not want to go back to regular gas. I thought everyone was just saying that when I heard it, but it is the truth.
Cost for the 5 gallon drum comes to around 30.00...
per gallon. That's a bit high considering toulene is about 3.00 a gallon with approximately 1.5 gallons needed to create a 100 octane mix with 93 pump with a 16 gallon tank.
How much of AVgas is needed to create a 100 octane rating with a full tank of gas....assume 16 gallon tank with 93 octane pump gas?
thx.
thx.
Probably 8 or so tanks...
5 gallons of T and top it off with 93 for 300+ miles of
Sunoco is now selling 100 at the pump for $4.50-- it ends up being the cheapest (lol) way to go.
