Twin1 misaligned, anyone else?
<center><img src="http://pictureposter.audiworld.com/125058/twin1misaligned.jpg"></center><p>Okay, if I get my Twin1 centered perfectly, it will slowly moved towards the driver side. It's not off by much, maybe 1/4". Anyone else see this. In the picture above I centered it just right.
Should I put a rubber washer to take up the slack on the driver side hanger? If not, what? If so, where could I get such a washer?
Thanks.
Thanks.
You could really use any sort of Nut/Washer(s) from a local hardware store. Ideally you would also..
want to make sure that the hanger arm does not slide out of the rubber hanger toward the pass side when you take hard turns. As long as the arm fits firmly against the rubber bushing, it should work fine.
Same issue, check my picposter
did you get and install the hanger extender from AWE? Once I installed it the exhaust hung perfectly...
Check their website and install guides...
jkownz
A4 (B8 Platform) Discussion
15
07-20-2009 10:14 AM
dagmz6s
Mid Atlantic Discussion
07-05-2006 03:52 PM
MachtigAvant (v3.0)
18
10-02-2003 05:58 PM
AudiJon
02-04-2003 06:50 PM
evan
06-04-2001 12:13 PM
