Updated, Rear Suspension Noise...need opinions...
Okay I have FK Coilovers in my car and since the day that they were installed the rear was very noisy while driving, this obviously made me quite angry so today finally I put my Stock rear suspension back in and absolutley no noise....
1)shocks or springs are defective???
2)possible worn out rubber mount on carrier and with stiffer suspension it is very noticeable.
3)My car does not want to be lowered
4)both 1 and 2
Thanks
4)both 1 and 2
Thanks
Hmm, nothing obvious...
but I guess you knew that. Here are some shots in the dark.
Did your coilovers have the springs pre-loaded? If the springs were loose without the weight of the car, maybe that caused clunking as you went over bumps.
Perhaps the shocks from the coilovers were not fully filled with oil and have no damping near the top of the travel. That would cause them to top out very easily as you unload over bumps. If you have one without the spring, you could pull the shaft out and see if it gets really easy near the end of the travel. Or, if they are pressurized, push one in and let it out, see if it speeds up near the end of travel.
Best of luck! It's a shame to not be able to use your toys.
dtompsett
03-20-2010 02:36 PM
fastdream
05-03-2005 07:14 PM
Justin517
02-23-2005 02:00 PM
FourRings
06-12-2001 07:13 AM
Matt G
12-09-1998 06:34 PM
