Vag-com questions, could someone help?
Just bought and used vag-com for first time last night. I tried to use throttle body adaptation to see how it works and it doesn't seem to do anything. I went to basic settings then 060 then go. It said run in the window and two seconds later OK. That doesn't seem like enough time. Is that right? Also, I went to measuring block and 115 to watch boost, but it is too hard. How does everyone get the neat graphs I see here on the site? The bottom of my vag screen doesn't seem to allow me to use the graphs button. Also got two codes. One 00955 Key 1 adaptation limit exceeded and 16846, Evap leak intermittent. Any help on what those mean? Anything else that would be useful for me to look at with the Vag-com. Thanks for your help.
Group 060, BS, make sure the count reading in box 3 goes to 8, then ADP = OK....
then your alignment should be fine.
Don't worry about the key adaptation limit, you should be able to use your other key fob. Just double check to see it works since the car might not have seen fob #2 for a while. I am pretty confident that this is what the code is related to. I usually don't take the central lock codes very seriously. I'm used to certain codes.
Evap leak?? we're you messing with the evap lines? check the black plastic evap lines by your exhaust also.
jcman
08-13-2012 06:01 PM
DonS4
11
11-26-2001 03:42 PM
