Water cooled turbos and circulation
I visit this site occasionaly as I almost bought an S4 last year. Can anyone answer this technical question regarding the turbos on this engine. I assume that they are water cooled and I was wondering how the water circulation system works.
1. Is it done with the engine's water pump alone?
2. Is it done with an independant electic water pump?
3. Is it a combination of both?
4. Is there post shutdown water curculation?
5. Is there an independant heat exchanger for the water used to cool the bearings?
Re: Water cooled turbos and circulation
The turbos are cooled by the main coolant circuit driven by the engine's water pump. There is a loop which splits off for each turbo. There is no auxiliary heat exchanger. Just the radiator.
There is an electric pump in the circuit which will continue the circulation of the water to the turbos when the engine is shut down. This operates only under conditions of high thermal load to protect the coolant from overheating.
Thanks for the info.
Do You know how the thermal conditions are measured?
Temperature sensor on turbo bearing housing?
Temperature of water returning from turbos?
Will the pump cycle off/on/off from the cooling of the water and subsequent heat soaking of the bearing caused by the exhaust housing?
All I know is from this excellent training guide written by Audi.
Go to the web site then:
Pick Audi S4
Pick Berichte on left side
Pick Audi S4 motor<ul><li><a href="http://audi-speed.com">http://audi-speed.com</a</li></ul>
Pick Audi S4
Crisqo09 T.O.
05-27-2005 10:50 PM
zotyo
04-06-2001 07:04 PM
bitrbo
17
08-25-2000 08:21 AM
