what causes that "honking" sound that bad DVs give you?
i get some type of a honk in my current valves when letting off the gas slowly during boost. theres
a "tss tss honk". Not sure if its the same honk. Just curious what this is, and if i should adjust them to divert more air (GFB stealth fx)
are you sure its the DV's? I think DV's only make that sound upon hard shifts....you might wanna...
check your tbb as that usually gives the "honk" sound upon lettin off the gas. Check F-hose as well if you have a 2000. I recommend doing a pressure test as well to find any other leaks. Good luck
co859
05-19-2005 09:57 PM
decoy99
06-08-2003 08:30 AM
sizquik
12
06-05-2003 09:30 AM
skabaru
08-29-2001 06:29 AM
