What rotors with old vortrag setup??
<center><img src="http://pictureposter.audiworld.com/43942/dsc00297.jpg"></center><p>i have the coleman 13" rotors with alcon B-type calipers. both the pads and rotors are completely worn.
the brakes came with the car, and i do not know what the dimensions of the rotors are. i alread spoke with stasis, with no good info.
it was the old Vortrag setup. any info, or direcrtion to find info is much appreciated.
Re: What rotors with old vortrag setup??
Get some replacement rotors from Coleman Machine or Porterfield Brakes. Get some new rotor hardware to mount the new rotors onto the rotor hat and torque them to 35 lb-ft.
Part No. D30-125-1300-762 for the rotors.
If it's the same setup I have...
the're probably 332x32 one-piece Colemans, no? My S4's original owner had already gone through the his Colemans and then replaced them with Stoptech's 332x32 two-piece rotors, no problem.
After wearing through those, I bought a set of Brembos from StaSIS, also 332x32. In that case, we added some shims under the caliper bracket to account for radial expansion of the rotor. But, they're not entirely necessary.
If you wanted to go bigger, you could also go with the 355x32s, but you would need to replace the mounting brackets and run 18" wheels or better.
Who'd you talk to at StaSIS?
HTH,
Jim
BTW, there are a lot of brake pad options for the Type-Bs. I'm using Pagid Orange, a little pricey but work both on the track and street.
HTH,
Jim
40v-V8
08-29-2007 02:04 PM
Ginseng Sniperâ„¢
10
10-18-2005 09:43 AM
P. Bauer
36
06-09-2003 03:48 PM
RS-Ralph
07-05-2001 06:18 PM
